Dies after starting - just changed lower manifold gaskets
ant.xlt.96
Roscoe, IL
Hey all, I'm having a head scratching moment. I just replaced the intake manifold, lower manifold, and valve cover gaskets due to a heavy coolant leak (head gasket was ruled out)
Now after getting everything back together, it starts but dies soon after. If I give it throttle, it'll run rough and blow out white smoke (not as much as before changing gaskets), but will cut out and die.
I've tried to start a thread in the Urgent help needed section, but haven't had any replies. http://www.therangerstation.com/forums/showthread.php?t=158805
The first issue was the fuel pressure regulator wasn't properly seated and I had to pop it back in place.
I have a check engine light, but it's not throwing any codes. I just have 4 incomplete codes.
At this point, any thing is helpful. Otherwise, I'm just going to have to tear it back down looking for what I missed.
Thanks.
Does it run if you give it a little gas?
Could be IAC.
Maybe it got contaminated by coolant.
How sure are you that your intake gaskets are sealed?
Yeah, I was thinking that it's probably best to take the intake off again and reassemble. Hopefully the leak is at that level and not the lower manifold. :sad:
Have you checked for leaks with carb or brake cleaner (or similar)
I have read it is hard to find leaks at the lower intake manifold interface.
I have also seen, in the tech section here, it is possible to torque the manifold without taking anything else apart.
Hey guys, thanks for all the tips! I loosened the intake bolts and re-torqued them and it started right up. I'm still dealing with the original problem, but I'll start a new thread for that. Thanks!
