ScottW
Hello Hello. I'm new to the forum here and also new to in depth Ranger work. As we were taking out my 4.0 to put in one with a non leaking head gasket and actually runs good we noticed my front differential had a leak, I didn't think much the other day but today I took a closer look and found that the front axle housing/case was cracked, specifically the far left tab that the pinch bolt goes down through. The metal on the left of the pinch bolt is pretty much cracked/coroded right through and I could knock it out with a screw driver if I wanted. So we have a parts truck which this motor was coming out of and I checked #'s and sure enough, everything is the same3.73's, Dana part number, etc...but when I looked at the same spot on the housing of the parts truck it appears the same thing is happening there but I'm not sure. It looks like their is much corrosion which I just got out from under and scraped a bunch out and put my fingers through the access in the left side of the LH support arm assembly and it feels like a crack/separation is starting but not complete, nor is their any leakage.
According to the exploded view in the tech library the left(driver) side of the axle housing looks like it's supposed to be totally flat on the left side, IS the picture correct and the side is supposed to be flat?
Is this a common problem?
Just looking for a little background and input from those more familiar than I. I love my Ranger, but today/yesterday has been a nightmare! I'm just hoping my parts axle housing ins't shot too, but I believe it is.
Scott
The first two pics. are from my truck which is definitely broken, the last two are from the parts truck which I believe is breaking also. It's such that it's real hard to see, but you'll see where I stuck my fingers from the side, and where my fingers are I feel a ridge the seems to be uneven and somewhat jagged seemingly starting to push out just as the other one did.
Scott
