Dana 30 SAS Leaf Springs
Powerpat
Appleton, WI
I'm looking for advice to do a mild Dana 30 swap into a 93 Ranger 2wd. My goal is to make the truck 4wd on 31" tires. What leaf springs would work best for this? I already have all the driveline parts needed for the swap.
Quite a few people have used the explorer leaf spring for front leaf setups with good results...
SVT
I used the Rancho 44044 leaf springs on mine, but they might give u more lift that u are looking for.
I am running YJ Springs with a helper leaf.
I would guess something like these mounted spring under. I ran stock yjs with an extra leaf sprung over and cleared 35s. Also depends on how you mount them to the frame and which end the shackle is on.
Sent from my SCH-I545 using Tapatalk 4
I would like to put the shackle in the rear for the better ride quality. So if I bought a set of stock YJ leafs and added a leaf I would probably be alright? There are a ton of these out there for sale cheap.
Running a rear shackle might be a little hard to get the correct pinion angle and caster without building a front drop mount like I had to with mine. With doing that you will be adding to the lift.
