- Oct 29, 2025
- Age
- 55
- Aurora
- State - Country
- TX - USA
- Other
- 2002 F250
- Vehicle
- Ford Bronco II
- Drive
- 4WD
- 2.8L
- Manual
- Total Lift
- None yet.
- Total Drop
- Stock.
- Tire Size
- 235/75/15
Having a small issue at the end of my Dana 28 axle rebuild. Bearings were changed 6 months ago, so its the same hub bearings. Replaced worn U joints, seals etc. Original shafts. At the end of assembly before the manual hub goes on, I'm unable to get the needle bearing, and thrust washer on past the c-clip groove. Its exactly the same on the other side. Any ideas? No problems up to this point.
