Buds94XLT
Been working through getting a 94 xlt 4.0 ohv back on the road and have been quite successful other than the following
I'm getting these codes all the time.
Koeo
185 and 186
Maf has been replaced albeit with a aftermarket version, output voltage was within spec when hooked up to see live data.
Koer
172
This dreaded thing. O2 sensors were replaced when I got the truck with Bosch, same as what was in there with the Ford name. Same issue. Ran a smoke test and found a single vac leak coming from the throttle body butterfly shaft. But this shouldn't center this to just one bank.
The only oddity here when hooked up to a scanner is the output voltage on the passenger side was pegged at 0v for a while before it finally started to show voltage. The drivers side was outputting voltage the entire time.
Now sometimes when I start the truck I get what sounds like a horrible exhaust leak on the passenger side and she runs rough with low rpm, hitting the gas a few times or waiting a couple minutes that goes away and it runs fine.
Idle sits around 800 to 850 so nothing out of the ordinary considering the small vac leak.
The main issue the truck had when I bought it was the bad capacitors in the PCM. Replacing those brought the entire truck to life.
Next thought is lower intake manifold gasket or exhaust gasket where manifold and downpipe connect before the o2 sensor. But before going that far, do any of you nice people have any other ideas?
Koeo
185 and 186
Koer
172
