haizrail
- Aug 12, 2016
- Automatic
Hello, and yes guys I'm back. Since my last post which was a while back, my starter went out and I'm having to put in a new radiator tomorrow. Oh and by the way guys I was able to change the cluster panel and get the check engine light working.
anyway, I hit a turkey about a month ago, and it took my drivers mirror clean off. I bought a powered mirror because it was cheap and with the manual mirror the turkey took off, the actual glass part of the manual mirror would move and get out of sync while going down the road.
and I know a powered mirror won't move. the only obstetrical in my way now is adjusting the thing to where I can see when I need too. I've been thinking for a while of converting my drivers door to powered since I'm handicapped in my left arm it's a pain to roll the window down/up or adjust the mirror for that matter. and I don't care about the passenger side at all.
I'm wondering what I would need to do to install a powered mirror and powered window. I really don't care if I have to run a switch and mount it else where in the truck for the (window). but I know the mirror is a different story because I'd need a joy stick to move the mirror up/down/left/right.
For the mirror I'd be ok with installing it and running it to something to control it temperately setting the mirror where it needs to be then disconnecting it.
any Ideas would be helpful. thanks guys.
