What about if I wanted to upgrade from my very tired 2.9 to a 4.0. From what I've read so far everything will swap over with the small issue of the starter. The 4.0 uses a bigger flywheel/clutch as well as I understand as well. I was hoping that a 2.9 distributor/cam would work in the 4.0 so I wouldn't have to make any wiring changes other than the starter. I was thinking if one used the 2.9 cam (if it fits, and the spec's aren't too different) than you might be able to used the distributor. Since the truck came with the distributor set up then the wiring would still work as well. What's the Major difference between the two engines with respect to the cams. I was thinking that the oil drive that sits in place of the distributor might just be a easy swap, but I guess not........
David
Swapping to a 4.0 and keeping the TFI distributor ignition is like
paying for an expensive hooker then ignoring her while you watch a taped baseball game and stuff cheetos in your face and wash then down with warm skunky beer...
The "wiring" isn't THAT big a deal... (it's more tedious than intellectually challenging) and frankly the two systems basically function (and are wired) very similarly...
If you actually look at the two ignition system diagrams in an
EVTM manual long enough it will hit you that the main difference
(Aside from the coil pack itself) that most of the wiring differences
are due to moving the various components around the engine bay.
Distributors can get wet inside the cap, TFI modules fail often, EDIS modules fail very rarely.
Frankly switching to a 4.0 is entirely justifed JUST for it's superior (reliability) ignition system. the additional torque and more truck like power band are simply icing on the cake...
As for the 4.0 starter/flywheel/clutch?
It all bolts right up to a 2.9, and many have done exactly that...
AD
