convert a 1987 ranger from manual to auto transmission
83RangerBill
My moms transmission went out again and I'm having trouble finding a replacement for it she's on a real limited budget. I can find an automatic transmission easier the truck is a 1987 ranger with the 2.3 and four wheel drive she lives in the boonies(so far in you can hear the banjos) any ideas on what I will need for parts? And wiring? Any help is greatly appreciated.
As far as what I know (and that might be wrong) the manual transfer case will work fine behind the auto EXCEPT you will have to make a filler for the trans tunnel for the other shifter.
The column will need exchange for the auto shift lever, the cooler lines up to the rad, the arm from the bottom of the column to the trans, a rad that has the cooler in it (most replacements simply have them so check for the fittings being there already) and you might have to change the cluster (if you want the shift indicator) Ironically my manual has an auto cluster (and column) in it.
to do the high to low range thing it will have to be in park, AND if you ever end up in nutural 4x4 the engine will have to be turned off to get the trans back into park, and the x-fer into a gear again.
once the trans is in park the engine can be restarted and normal shifting again.
All the wiring for the electrical x-fer case, IMO, is a waste of time and money, unless you want nothing on the trans tunnel.
Greg
Column and floor panel should be right or close to it. 87 would have been floor shift auto.
What trans am I looking for
Sent from my DROID RAZR using Tapatalk
A4LD or C4/C5.
Thank you
