SRD
- Jun 18, 2021
- Las Vegas
- 3.0 V6
- Automatic
Hello. I have tried to repair my 99 ranger XLT 3.0 for over a year with no luck what so ever. I have court soon as I cannot register the truck got a ticket as I cannot get the CE light to go off to pass SMOG so am at risk of losing my work truck all together.
The truck CE light just will not go away no matter what I do to fix it. I am not a mechanic just trying to fix my own truck if possible.
**ISSUE: I have had multiple CE lights that mix as I chage the DPFE. I have cleaned and replaced my EGR, etc......I am jst lost.
The CODES finally went away on their own after I replaced the DPFE and Pigtail...but the code still showed in the OBD2 so I cleared it and went to get a SMOG. The smog guy said it failed as I cannot clear codes I have to wait 50 miles...so I did and the light came back!!!!!!!!!!!!!!!!
**WHY did it go away on its own then come back with more and more codes over and over?????
CODES are as follows: They codes mix as I change the DPFE sensors but never go away.....I have used OEM and 3rd party. OEM pigtail....I changed gas cap.
p1400: DPF EGR Sensor Circuit Low Voltage Detected
p1401: DPF EGR Sensor Circuit High Voltage Detected
p0402: EGR flow excessive detected.
*Any idea of someone who can walk me through wat to do step by step to help me discover the actual issue would be MUCH appreciated.
Thanks
SRD
Thanks
SRD
