- Sep 2, 2025
- Bushnell
- State - Country
- FL - USA
- Other
- Sumter swap meet
- Vehicle
- Ford Ranger
- Drive
- 2WD
- Automatic
- Tire Size
- 225/60/15
Hello everyone. I am new here so i will give some background. My16 year old grandson was gifted a 97 ranger 2.3, automatic that ran when parked 5 years ago. We have cleaned the fuel system and installed a new pump, replaced timing belt ,plugs, wires, fuel injectors, MAF,TPS and IAC. Compression is 160 psi per cylinder with engine warm and fuel pressure is 40 psi and the pressure return valve works. It is setting a P1121 code. TPS A inconsistent with MAF/MAP. The timing is hovering around zero at idle and does not advance beyond 25 degrees total. Vacuum at idle is 15 inches and goes up to 18 when RPM is increased. It idles rough and is running rich. I was wondering if someone might have experience with this code and what the solution was.
