exigent
- May 13, 2008
- Age
- 44
First off hello everyone as this is my first post. I have a 98 2.5 5spd. Clutch grenaded on me the other day. The "hub" inside the disc stripped out while driving 45mph about 1 minute after the last shift... neat huh? When i say stripped I mean the splines are fine... the hub itself broke loose from the rest of the disc. I only include these details for later reference.
Now... this is not my first clutch replacement however I am stumped. Replaced clutch disc, pressure plate, pilot bearing(NOTE: which had no pins left in it what-so-ever), slave cyl, and TOB. Flywheel is nice and clean (clutch didn't wear out remember) and everything "looks" okay. Bled the system (WHAT A PAIN) and got good travel and release. I jump in start the engine in neutral with the clutch in and attempt to shift to first... NOPE. So I think I didn't bleed it well enough... so I bleed it about 30 more times... Still not able to shift from idle. If I start it in first I can drive and shift just fine. Clutch operates nicely, releases for upshifts okay and downshifts with a bit of effort. Drove around 2 mi to see if pilot bearing would "burn in" and no... it DID get a little better but no where near right.
Soooo.... tonight I pull the trans back out and find something odd. The hub of the clutch disc has rubbed against the very end of the slave cylinder. I don't mean a scuff either it has melted about 1/16" of the slave cylinder off. There is still a safe amount of plastic left to hold the retention ring in place but I don't get how this even happened. I triple checked the slave cylinder to make sure it was seated correctly. I measured the height of the old slave vs. the new to make sure it wasn't simply taller. I can't figure a way that the clutch disc should ever be able to touch the slave cylinder but it has and Im lost.
1. When I first pulled the trans the "guts" of the old pilot bearing were gone. I found a couple of pins in the back of the crankshaft but nothing was holding the input shaft from rolling all around. If I try to move the input shaft side to side it moves A LOT. About 1/4" either direction. I have no experience with this trans is this normal or is this what happens when you have no pilot bushing for 30,000+ miles. Trans is out and open rite now... should I replace the bearings on the input shaft? Please advise.
2. How the HECK does the disc hit the slave cylinder! #$%#$%# I assume the slave cylinder was pressing the disc against the flywheel causing my no shift problem.... BUT WHY!!?!?!?!?? The slave cylinder properly seated is in a very specific location a certain distance from the flywheel. The disc is pinched directly against the flywheel.... under what circumstances could they bind? The Aluminum "shim" is in place between the engine and transmission. Is there a reason I would need a thicker shim?
Oh and the disc can ONLY be installed one way... No... i didn't install it backwards.
