What Adams said. You can rent them at just about any auto parts store if you want to use the correct tools. Plus you're not gonna mess your knuckles up too much.
Yeah, some stores rent the wrench set. I have this fancy jig that goes in my air chisel, but it's not cheap, and the chisel isn't cheap, and you need a pretty good air system for it to work on most vehicles.
On my 92 3.0 v6 it was a 7/8 wrench. I had to remove the waterpump and lock it in a vise on the waterpump fan to remove the bolt for the fan housing and cluth
My father inlaw did mine by swapping two of the four pulley bolts for longer threads, and using flat iron on the ends sticking out the back. Worked OK for putting the fan on too.
For
