oldford4x4
I have been going through my wiring on a '86 BII and got to the point where I was checking the 8-pin connector from Pin 8- Y/W to Pins 4-7. I am showing "Open" on all pins. I went through this multiple times to confirm "Open" at all resistance settings on my multi-meter (.01 ohm-20000 ohms). Am I definitely looking at a bad electronic shift motor or is there something else with the position check that can be done to further check my problem? I plan to replace the motor with a parts store unit if that is definitely my only possible issue. Currently the vehicle is in 2 HI and when the system is all fully connected, pressing the switch results in nothing (clicks/flashing lights, etc., just silence). The self check passes with a flashing light, and the other two harnesses check out okay. The plug at the T-case does not have any visible corrosion issues.
