holyford86
Some guy with a problem
⭐Supporting Member
💻 TRS Socials
Boosted (Not Stock)
GMRS Radio License
- Aug 6, 2007
- Age
- 40
- Plattsburgh
- State - Country
- NY - USA
- many
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 4.0L
- Total Lift
- 7
- Tire Size
- 33x12.50R15
So with me being a bit of a nerd, I stumbled upon the fact these types of fans exist and many people have kind of hacked them to make them kinda work on older stuff. This interests me because it gets rid of one of the greatest annoyances I have with traditional electric fans, the noise... It appears that you can somewhat easily make them ramp up as tempurature increases and hold that rpm if the temp remains constant (ex: 20% duty cycle at 195 degrees, 100% at 220) it appears that you can make an arduino control this type of setup without much work (if you code, I don't, haha). From the reading I've done it appears that the Bosch fans are somewhat common and easily accessible in the junkyard near me, and controlling them is something somewhat simple. What I havent seen yet is anyone integrating this sort of thing in such a way to use the factory coolant temp sensor as a reference to the arduino, which should be possible in theory.
Has anyone else dabbled in this sort of thing? Any good resources for this? I have stumbled upon a good forum post talking about this stuff but it seems to be mostly centered around gm and holley efi (with some microsquirt thrown in)
