Bronco2 90 stock max tire Size 15x8 ??????
buzz88
Southeast PA
Anyone know the max tire size to run on a 15x8 wheel on a 90 Bronco II. I ran 30x9.5x15s on my 88 but it had a 2 in suspension lift in the front, can I get away with that for normal driving no real off roading, on a 90 b2 without any lift???? thanks
i had 30x9.5x15 on my stock ranger rims and it was a 90, i think you could fit 31x10.5s on it you might have a little rub at full turn but that should be it, my truck was just stock and sagging leaf springs and it had no prob with the 30'' tires
I have 235/75/15s with little rubbing, but I've got mb razors for a jeep so it has very little or negative offset. The same tires had no rubbing issue at all with the factory 15x6 wheels.
yeah I want 15x8 wheels which I had on my 88, gave it a good wide stance, but i guess it will depend on the offse of the rims, i saw some general grabber ta tires in size 255 70 15, which are basically 29x9.5 15s ...
i have a friend who used to run 32x11.50s on his 89 B2 which had just heavy duty stock height coil springs and only rubbed at full turn or full stuff of the fenderwell
i dont know how they will ride and drive yet but if you look at my build thread you will see 31x10.50x15's on stock alum wheels. they fill the fenders quite a bit and I am afraid that they will rub a lot. The Bronco has factory sprins and no lift at all at this point.
Paul
