Bronco II susp. lift ?
tomahawk350
Solid Axle Swap
Johnstown, PA
2.9 V6
I missed out on a 4" susp. lift on ebay that went for $75.
My question is with a 4" lift what is done typically with the draftshafts? Do they have to be lengthened? My bronco II has the CV style rear dshaft.
What about a 2 or 3" susp. lift?
You mean driveshafts? They don't need to be lengthened. but as far as a four inch lift you will need drop brackets, extended brake lines, longer pitman arm.
If your looking for a cheap four inch lift I would go with two inch coil spacers and add a leafs, and a 2 inch body lift. shouldn't cost more than two hundred bucks
You'll need a u-joint rear shaft, the cv shaft can't handle much lift, it any. The front will be fine.
Yea, I figured. Does anyone know if a ranger u-joint driveshaft would bolt in place of my stock GNK style? After being lifted i mean.....
Even if it doesn't, having a driveshaft retubed is not very expensive.
yea, I know that, but does rangers use the same bolt flanges?
