gtstang03
- Dec 9, 2007
- Age
- 42
- Automatic
Hey guys i have 88 b2 4x4.
I went out this morning to drive to work and the depressed the clutch and it felt wierd.
I instantly new it was either clutch master or slace cylinder.
I checked the clutch fluid, which appeared to be perfectly fine, level wise, little dirty.
New new leaks on the ground, well no more then normal. LOL
So i pull it in the garage crawl under there and appears to be now brake/clutch fluid anywhere, although it could be covered up by slow valve cover gasket oil leak thats has coated everything pretty well.
I check the master cylinder and there is no leaks anywhere.
As i have seen int he past on other vehicles usually the either will be leaking when bad.
So my next step, i pinched the line going to the slaves since if it was the slave i was going to replace anyways.
I pinched and the clutch pedal will got hard but still went down slowly, and come back slowly. Release the pinch and it goes back the spongy feel.
So i am lost, is it the master, slave, or just need to be bleed some more.
Please any info or help would be gratefull.
I really do not want to drop the transmission if i don't have too.
Thansk
Thansk
