Broken fuel line
FORDboy357
I broke this little bastard trying to get the hose clamp back on the thermostat housing. It's either the feed or return line from/to the pump to/from the rail. No exploded view I've found shows this piece so I don't know what to call it at the parts store. It goes into a braided line that quick connects behind the power steering pump. Winter is coming and I need my truck.
Sent from my XT1254 using Tapatalk
97 ranger 4wd 4.0 ohv by the way
Would be the Return line coming out of the Fuel Pressure Regulator(FPR).
The return line is not high pressure, IN line is 35-45psi and is on the drivers side lower intake(fuel rail).
So you could probably cut the hose and use barbed insert and hose clamp to repair, with a 90 that fit FPR connector
