Brief Engine Shut Off While Driving
DeadEye200321
Forum Member
💻 TRS Socials
Arizona
AZ - USA
Vehicle
Drive
4.0L
4" Super Lift
33"
Hello Everyone!
I’m in some dire need of helping figuring out this issue I’m having, I have a 2004 ford ranger FX4. So the issue I noticed it yesterday 7/8, driving home from work I briefly lost engine power maybe only a second or two and then the engine went right back to being normal and saw the passive anti-theft (PAT) light flash on my dish light at the same time. Does anybody have any clue as to why this would happen? I didn’t hit any large bump that would throw a connector around I don’t think and as far as I can tell, all my connections in the engine bay and by my feet and passenger kick panel are good as well. Does anybody know where the PAT lights/system wire into some I could check that out? Let me know what you guys think and what I should take a look at, thank you everyone!!
Do you have a heavy keychain or a lot of keys connected to the truck key? Is your truck key heavily worn?
Has to be a connection issue somewhere like mentioned above in the key switch or a bad relay or bad capacitor in the engine computer or something dumb...
Check for a bad ground.
I had that issue a few years ago. The engine would shut off, then start. It did it on the freeway and city driving. In my case, only the engine shut off. Lights, radio, everything else continued to work. It turned out to be the MAF. Once I replaced it and never had a problem since then.
Upcoming TRS Events
Featured Ranger Based Vehicle
