GrandpaSquid
- Sep 17, 2023
- South carolina
- 4.0 V6
- Automatic
The other day I noticed that with no key in the ignition pressing the brake pedal cut the radio on. Truck is 93 Ranger 4.0 Auto. I used all the factory wires when installing the upgraded sound system. I used one of those plug and play wiring adaptors for the head unit, as well as premade connectors to the cabin speakers so none of the factory loom is cut. There are two 8" subs powered by one amp while the four cabin speakers are run off another amp. The ignition is a little wonky the lock ring(silver part with the wings) spins and the key warning chime will go off if you knock it to the wrong position. Been like that since I bought the truck, radio has only started a few days ago. I attached a video, don't really expect to get a solution just thought it was funny, but help is appreciated.
