wrecking-crew
- Sep 6, 2008
- Age
- 35
- dirty jersey
- 06 chevy
what bigger gas tank can i fit into my ranger. i got the stock 14gal? supercab 4x4 single tank
The '86-88 Supercab can be fitted with the tank from a 91-97 supercab.
I upgraded mine from the stock 14.5gallon tank to the 89-90 Supercab tank.
This required:
1) replacing the top of the crossmember that ties the two
leaf spring mounts together.
2)Rerouting and shortening the fuel lines.
3)Adding the additional crossmember over the rear axle
(a crossmember that your truck simply doesn't have)
4)replacing (or removing) the center support bearing
crossmember.
5)Enlarging the keyhole slots in the frame for the wider straps
used on the later plastic Tanks.
I went a step beyond that after going through all that work
to upgrade from a 14.5gallon tank to a 17.0 gal tank I was
happy for several years, then I discovered that there was
an even larger tank... used in the mid-'90 and up supercabs
that holds 21gallons of fuel
That was a simple bolt in to replace the 17gal tank, because I had already done all the necissary work to get the 17gal on there.
That is NOT where I stopped but what I did next was WAY beyond
the scope of your question...
I'll let someone else tell the rest of the story
But I will say that on my recent return trip to Pennsylvania
from Indiana towing another Ranger on a dolly when I got
home I had nearly enough fuel left that I could have
disconnected the dolly turned around and drove back...
Or done a round trip to Kittery, Maine...
AD
I'll finish the story because I've got some to add... AllanD has an aux tank (not the crappy Ranger one either)... The rear (square) tank from a early 90's Ford full-size truck 1/2/350 will fit... You can also use the MASSIVE 32 gallon tank from a full-size Bronco that will fit where the spare tire does... You must of course do some cutting, but having 53 gallons of fuel onboard would be a real nice thing... There was a article about this, but I can't seem to find it anymore... It was on www.explorer4x4.com but I don't remember exactly where...
BTW - All these options are good for a 2wd highway runner, or a 4x4 with some body lift... (The tanks are quite a bit deeper than the Ranger frame is [especially the Bronco tank])
Uhhh... Not exactly.
a Normal F-series tank won't fit and the 32gal full size bronco tank won't come close to fitting....
The "aux" tank I use actually came from a "narrow frame" F-350/450
in short an F350/450 with dualie rear wheels has a narrower frame
spacing behind the cab and THAT tank will fit. It's 21.55gallons
when topped up.
that plus the 23gal and change up front...
But that isn't the whole story.
I have a "diamond plate toolbox" in my bed.
the toolbox is an illusion because there is barely enough room inside
it for a few quarts of oil, a can of fix-a-flat and a lug wrench.
I could probably add my mail provided I didn't get much junkmail on that particular day, but not much else. inside the aluminum toolbox is another
fuel tank that holds nearly another 40gallons.
AD
damn allan how many gas tanks do you need
My 96 Ranger Super cab 2.3L has a 20gallon tank.
Truely, how fuel does the Ranger really need to hold? Unless you are doing a long distance trips all the time, I don't see the point going beyond 20gallons.
Why? Well I buy the gas they sell off at the local junkyard after
they drain it from the junkers![]()
The more I carry with me the less I have to buy on the road.
