Beanmachine7000
couldn't you just have a regular fuel system with one tank and one feed return and vent or whatever then have low pressure pumps in your aux tanks pump to fuel to the main tank. just put the pumps on a switch to pump in the main tank when it starts to get low.
In theory it seems like it would work, but it would be a very good way to have the dreaded "fuel being pumped into the tank that's already full" scenario... It also seems like a good way to burn up a fuel pump, I mean if you have to turn on a transfer pump, then it would have to be turned off, and relying on someone to remember to turn it off after its empty (however you could tell that) just seems like inviting someone (me) to leave it on and burn up the pump...
Now, OTOH... It seems like gravity feed would work well, but, there really wouldn't be anyway to do it... The rear (aux) tank would be higher in relation to the front (main) tank, so you would have to fill from the rear tank (which would require a new filler hose, which would be the same amount of work as a selector valve application)... Gravity feeding would work fabulously for a in-bed tank, alas, my Explorer has no bed, and I'm sure not going to keep a giant tank of gasoline where my rear seats would be...
