- Feb 9, 2010
- Age
- 36
- Menomonie, WI
- 4.0 V6
- Manual
- Total Lift
- 3"
- Tire Size
- 37x12.50 Pitbull Rocker MTs
- My credo
- Custom everything! Purists look out!
So I have more time to update and here goes!
I extended my front drive shaft, I just sleeved it with .120 wall tubing:
Next I extended my steering shaft (from steering wheel to steering pump, only half done in the picture)
Shocks were next:
Full droop:
I had cut and reinforced the K Member earlier as you can see in this picture but I only had about 2 inches of up travel when both tires would stuff (speed bumps or high speed whoops, not that Im racing)
I remember reading a build thread where a guy cut his cross member and welded a .5" plate underneath... .5" is a little overboard so I was going to go with 5/16th but the metal place didnt have any but they did have 1/4" AR plate (Abrasion Resistant.) Its basically heat treated, I dont know if it was AR500 or less but non the less it worked great:
Chopped:
AR plate (labeled "NO SHEAR" because they would break their die if they did so) The lines are for clearancing the oil pan:
I burned it in and welded the K Member to the plate and I had MUCH more clearance then! (for the ones with sharp eyes you can see I had to run true dual exhaust because the drivers side exhaust hit the front driveshaft.
After that I made sure everything was tight and fully welded and I took it out to the RTI ramp:
I had an axle seal leak too... Depressing because that meant I would have to pull the carrier!
The story on the differential seal... I put the new seal in and all was good but then my axle shafts were rubbing on the inner knuckle so out with the shafts and the fix was one washer on the inside of the spindle, this pulled the shafts away from the knuckle enough not to rub. When I put the axle seal in I didnt pound it in enough so when I put the shafts back in I knocked it loose... a day before Easter Jeep Safari it started leaking again so out with the shafts and carrier to pound it in the full amount this time (hopefully for the last time)
I welded up the holes in the fenders and painted them too:
I changed my spark plugs and fuel filter before the trip too. The fuel was DIRTY! I also forgot to relieve pressure in the lines and got +70 psi of fuel squirted all over me.
Fancy plugs:
Next is the MOAB Easter Jeep Safari trip. Updates Coming Soon!
Shocks were next:
Full droop:
Chopped:
Fancy plugs:
I guess Ill be upgrading to 37's earlier than expected
