Big Block Drift Truck - Pic Heavy
After the transmission cross member situation i started mount the raised radius arm mounts before i paint them. they fit perfect but i did have to trim the edge of the front cab mounts in order for the radius arm mounts to sit flush.
I did have to enlarge one hole and drill another additional hole
tried to install the raised transmission cross member today and noticed that the holes are a bit off, so i decided to hold off on modifying it to fit correctly until i mount the motor and transmission in the spot i like, just in case i need to move the cross member farther back from the stock location.
Flip it over and put the D facing down
with the ttb/tib longer is better.
when lowered though with restricted movement its not really as critical.
you want some caster though in either case. i prefer it to be heavier.
