- Oct 9, 2009
- Midwest City
- State - Country
- OK - USA
- Drive
- 2WD
- Automatic
More of a race truck than mine for sure. My performance mods currently consist of a K&N air filter. Hopefully that will change in the future. Thats interesting you get such good gas mileage. Does the JET Chip help you run at higher RPM?
Yes, it changes the shift points to higher up the rpm band. Also changes the short term fuel trims and the timing, hence the need to run 93 octane. It's an old, old chip. Been on the truck many years. Considering getting a handheld tuning device, such as a SCT X4. Those are the best, plus they come with a bracket to allow it to be dash mounted. It also has gauge functions for any of the items the OBD II system covers.
I've taken the chip off and re-installed it a few times. I can tell it's there. Same with the cai. Some here insist they do nothing. Yet when I remove mine and put the stock system back on, I'm like :where's the beef?" I can tell the difference. I also tried running the stock box with the three inch tube from the MAF to the TB. Didn't do a damn thing. Tried running the stock pinched down tube with the open filter, didn't do a damn thing. Put the cai back on, back to the way I love it. So the stock system went the round-open-top-file route, so I'll never be tempted to put it on, ever again.
Yeah, the 20.03 surprised me, as it came after the 4.10 install. Only thing I can assume is the 3.0 is mucho happier revving higher. Also the good mileage came after a nice shift kit was installed in the transmission along with the 4.10 gears. And with the 4.10 gears, the truck shifts into OD at a lower speed than it did before, and the torque converter clutch locks up at a lower speed than it did before. All that may help. Truck also doesn't shift out of OD as often as it used to, and that includes going uphill. Doesn't hunt around between Drive and OD like it used to between 40 and 45. Goes into OD solid and stays there.
