Belltech 6400 leveling question.
richard booth
Tacoma wa
I am replacing my old B2 leaf shackles w the belltech 6400 ones, question is how much will I need to "spacer" the front coils to get it level? looks like when you add an inch to the coil spring in the form of a spacer you end up w more than an inch? Most threads I have seen say you add 1 & 1/2" with the chevy drop shackles. Will I end up reasonably "level" if I do 1" of spacer under the coil spring (welding appropriate size washers) and putting the adjustable caster/camber bushings in before it goes to the alignment shop. http://www.therangerstation.com/forums/images/smilies/shok.gif
