Bar Pin Eliminators for the forward shocks on 2005 Ranger Edge Torsion suspension: Suggestions?
dviensanchez
Forum Member
💻 TRS Socials
U.S. Military - Active
Chula Vista
CA - USA
Vehicle
Drive
Two rules: 1)No hits to the crotch 2) Home by dinner. GOD, FAMILY, COUNTRY, and OEM PARTS
Hello again fellow Ranger enthusiasts. I’m trying to pick anyone’s brain on where I can find some reliable Bar Pin Eliminators for my front Bilstein shocks to be mounted on my lower control arms….. Recently bought some stock ride height 4600s that come with a bar pin lower mount. But I’m trying to get just a little more clearance about an inch or two. Any suggestions? I’m also open to any safe rigging thay anyone’s tried involving spacers and such. Mainly tryin to go BPE route but so far I’m finding jeep focused products mostly.
Above is the item I’m replacing old shocks with.
My removed OEM shock- Note that the original has the fasteners permanently fixed onto bar pin mount. I’m trying to capitalize on the removable bar pin on the new Bilsteins to give me a very minor lift on the shocks.
Got a welder?
Or just use the Jeep ones if they’re the right size.
My Choptop when I built my extended front control arms (TTB suspension) the pins for mounting the shock were broken. I wasn’t really a fan of the stock setup anyway so I welded a couple shock tabs to the arms and called it good. Works great and takes a normal bolt instead of a pressed-in pin now.
