rs1971
- May 10, 2009
- Automatic
Hi All,
First a quick bit of background: I have a 2003 Ford Ranger with the 4.0L V6. It's a 4x4 with a manual transmission. At about 60k miles and 4 and a half years ago, my clutch slave cylinder went bad. Obviously I had it replaced.
Everything has been fine until about a week and a half ago when it started behaving similarly. I wasn't really having trouble shifting gears, but the pedal was really soft, only catching at the very bottom. I have recently moved, so I called a different mechanic than the one who did the work the first time. He only spent a few minutes looking at it and really only at the reservoir (which was empty) and right in that area for leaks. He said that he didn't see anything and that it had to be the slave cylinder.
After he left, I filled the reservoir and that seems to have helped a lot. I realize that this likely isn't a solution as it must be leaking from somewhere. But I'm just adding it for completeness. Anyway, I just have a couple of quick questions since I am 90% clueless about this stuff. Is there any reason to hope that he is wrong and that it might be the master cylinder? And if not, is it unusual to go through two slave cylinders in 99k miles?
Thanks in advance for any input anyone might have.
