Backwards fun truck
We have a club Halloween run scheduled for Nov. 1st and I volunteered to bring this mess so now I have to get it done! I got it off the trailer and into the shop yesterday. Clutch is done, that was a fairly easy project as usual although I don't care for the weird bellhousing bolt locations and head sizes on 3.0 trucks. It throws off my tool list that I get out by default for these jobs. I also found that the exhaust had been off recently so the Y pipe was very easy to remove. I was very pleased about that, makes it much easier.
The clutch was definitely toast. New clutch and flywheel were only $110 from RockAuto on clearance. I pulled the top cover on the trans while I had it out and glanced over everything, there were no chunks in the fluid and not much for metal shavings or anything bad looking, just dirty fluid, so I'm happy to report that. I was a little worried that the previous owner had grenaded it when it got stuck in gear and then I'd be assembling a transmission in addition to a clutch job.
My original plan was to put a 1350 manual t-case in this so that it is still 4wd and I did do that but I do not have the right shifter parts. I don't know if I ever did - the little arm on the t-case is mainly what I am missing. I think it might be a one or two year part - 88/89 truck with a 4 cylinder and M5OD and I've only had one of those ever. Those would have also come with D28's....... and I also don't have a driveshaft... I have one from an automatic but it's too long by at least an inch. I found one that had "FM-145" written on it that's almost too short but it'll be good enough. Plan for the shifter deal is to just leave the floor plate off and I'm going to leave some vise grips attached to the t-case in case I need 4wd.
After confirming that the clutch and stuff is working and bled, I moved on to exhaust. This truck will never see the road again but I don't want it to be really loud. I'm going to leave it parked in the woods so I also don't want it straight piped with no spark arrestor. I did a lot of digging in my muffler parts stash and came up with some things that fit together: my Y pipe adapter, a piece of chain link fence post, a minty knockoff Flowmaster that I found on the street in front of my house, and a short driveshaft chunk to make it long enough to fit into the rear exhaust hanger. The only other muffler I had is huge and wouldn't fit. Sounds pretty stupid but it's not super loud!
This evening I'm going to test drive it in the yard to make sure it moves forward and backward and then sweep the shop. This thing was not only incredibly rusty (think cab mounts falling off, etc) but it was packed with mud. Once I can work in there again I am going to swap the steering box, and work on cleaning up the interior a bit. Mainly just so that our participants can sit in it without getting filthy - the carpet is junk and the seats are pretty gross. There is a bunch of broken glass and stuff floating in there too that I need to clean up.
To-do list:
- clean interior
- make new floor plate to close up the hole where the t-case shifter was (for storage purposes mainly.)
- swap steering boxes
- straighten rear bumper so it's not pointing straight down
- check fluids
- ignition lock cylinder, need to replace this, the "wings" broke off
- wheel bearings are a bit loose, not sure if I care enough to fix this
- hubs may not be in very good shape... the bit snap rings are gone and the guts are sort of floating. Not sure if I care about this either.
- need to round up a few more traffic cones. I'm thinking 10 may be good, I have 5 so far.
Cost breakdown: sold the tool box for $80, bought clutch parts for $110, so $330 deep into it. Hoping the cats are worth maybe $150. Still need to transfer the title so I will have some expense with that. I'm pretty happy with where I landed cost wise though, $2-300 into a fun toy like this is perfect.
More to come.
Pulled it outside last night, it moves under its own power in both directions. Something is up with the transmission, it seems like it almost gets stuck in reverse and I can't shift into 5th at all. May be something bent or broken in the top cover or the 5th/rev cluster. 1-4 work fine but are kinda weird and don't engage smoothly. Nothing grinds though, very strange problem, but on the bright side I don't care! It's good enough.
I got the interior cleaned up last night. Threw the carpet away and spent over an hour shampooing just the seat bottoms. That seems like a lot of work for such a piece of crap truck but the passenger side one had something brown spilled on it. Maybe poop, maybe a chew spitter, maybe who knows what but it was so bad that I couldn't sit on it, much less ask someone else to sit on it. The driver's side was just dirty. Weather looks pretty nice the next few days so they will dry out and be ready to go by the 1st.
Floor plate is done, just took a blank one from an automatic truck and cut a circular hole in the middle for the shifter to poke out of. Taped around it, should somewhat keep the mice out when I'm not using the truck.
Fluids are good, ignition lock cylinder is swapped, now it starts every time.
This evening I am going to swap steering boxes and straighten out the bumper, maybe a couple of other things. Decided I don't care about the hubs or wheel bearings. That is a problem for another year. Excited to go play with this in a couple weeks, maybe I will jump it or something cool.
I changed my mind. I pulled the manual hubs and put a pair of junk auto ones on it. No reason to needlessly use good parts here. That cleared up the front end slop on the driver's side but the passenger side needs ball joints and I'm not going to dig into it that far.
Steering box is swapped, what I thought would be the hard part (lifting the box into place, lining it up with the column, and bolting it down) was actually the easy part. The return line was so rusty that it ripped open while I was trying to remove it... then to make matters worse what was left of it got caught on the old steering box as it fell out of the truck and broke the nipple off the pump reservoir. Fortunately I had spare parts in my junk stash, just annoying to burn up an hour because of a mistake.
Still need to straighten the bumper but otherwise we're good to go!!!!
