Kozanatos
- Jan 26, 2011
Back from the DEAD
1984 Ford Ranger V6 2.8L 4SPD 4WD
Ranger has been sitting around 6 years or so.
Rebuilt the carburetor - Never done that before. Its the stock motorcraft carb from what I can tell.
New fuel filter on Rebuilt carburetor
Siphoned all old fuel out of tank- didn't even try to run the truck. used the fuel line that goes to the carb and pumped it all out until it was dry, then flushed it with a gallon of good fuel. //edit --- It didn't help. I need to drop the tank.
Inline fuel filter - after the gas tank, but before the mechanical fuel pump
Spark Plugs, the old ones were black and way over gapped ( so i was told )
Plug wires in - Just seemed like the thing to do
Oil + Filter change 5w40 - For the cold weather
To Do:
Circulation tank heater - While it is warm
Drop Tank - Clean, Replace fuel sender?
Starter - Rebuild Starter
Compression check
Manual Hubs
To Do:
Compression check
Manual Hubs
