B2 Drive Shaft LENGTH?? and... CV Vs UNIVERSAL JOINT ????
Featured Build Threads
BabyBronco89
GR Michigan
okay so i have a stock suspension on my 1989 B2 fm 146 trans and orig elect shift trans case
the 89 originally came with a CV style rear the original has since blown and been replaced with a professionally rebuilt unit and it just failed. this one lasted me a yr.
so i hate the CV STYLE!!!
SO i found a universal joint type driveshaft with a slip joint a week ago on a older i think 86-84 B2 with a auto trans and man tcase it has the same flanges
So IS THERE DIFFERENT REAR DRIVESHAFT LENGTHS FOR THE 4x4 B2????????
so going to junk yard after i get out of work tom ( if it will work) and i hope that shaft is still there
THE 4.0 JUST HAS TOO MUCH POWER!!!!
that little CV joint didnt stand a chance
If the donor has an A4LD transmission it will work. A C-3 or C5 may not, I don't think they are the same length. But the A4LD and the FM146 are and the driveshafts can be swapped.
Thanks so what year did they start using the a4ld?
And they used all three of these trans as options for the 2.9??
I think the A4LD was introduced in 86 along with the 2.9. I'm not sure if the C series ever came behind a 2.9 from, factory, but there is a great article in the TRS tech library about transmissions.
right on thanks, Adam!
So i got to the junkyard after work yesterday 10 mins to close
and once i got a closer look at the shaft i had spotted i found out that it is a custom fit shaft and its very nicely made and very heavy duty, with greaseable u-joints.
so junk yard score @ 35$ , feels great to get lucky for once :D
Event Coverage
Featured Ranger Based Vehicle
