axle pivot bolts
maroon ranger
East Helena, Montana
1994 4.0L proje
I have looked every where and I just for the life of me can't figure this out!!!!! But what are the size and grade (or metric) of the two axle pivot bolts? And also the bolts/studs that connect the radius arms to the front axles? And on the bushing side of the radius arms, is that a 3/4 inch stover nut?
I can't help you on the pivot bolts, but I'm pretty sure the radius arm nuts are 1 1/8".
Yes, stover nuts (nylocks can be used as well).
The pivot bolts are 14mm (sorry I don't have the length). 9/16" bolts can be substituted.
Axle-to-arm bolts are 3/4" SAE (D35).
O.K. thanx!!! Are those axle pivot bolts only threaded on the ends or threaded all the way? And would I use washers on the nut side of the pivot bolts or both sides?
No, they don't have to be threaded all the way.
I used washers on both sides on mine.
