hat_man
- Jun 29, 2013
- Manual
Hello all.
I haven't posted here in quite some time. I still come in and look around from time to time though.
My old '97 Ranger finally died and I bought a "new" '03. From the reading I have done here I am wanting to swap out the rear end to one with the 3.55 gears. I'm sure this comes as a surprise to most here, but let me explain. My daily drive to work is anywhere from 90-120 miles round trip on almost all two lane blacktops at 55 mph. Occasionally I'll end up on the interstate at 65 but only for 5-10 miles at most. My current Ranger is a 2003 XL with the 2.3L and a 5 speed manual and a 7.5" rear with 3.73 gears. At 55mph I'm cruising at about 2k rpm and currently getting 30 mpg in the winter and 33 mpg in the summer. Most would say "Don't mess with it." or more often than not "There's no way you're getting that. You can't do math." I've been tracking my mileage for years and have figured out how to drive the truck for mileage.
The one thing I have noticed is that when I am going from a 45 zone to a 55 zone the engine really settles down and is almost un-noticeable at around 1800 rpm. It's smooth as glass. I can only guess that it is at it's most efficient point in that range. The center of the BSFC "island" if you will. The problem is, at that rpm range I'm at about 48-50 mph and I'm not going to be the one holding up traffic. After doing the math I find a 3.55 puts me in the 1850 rpm range at 55 mph. Seems perfect for my situation. The 3.55 was offered in a few configurations so that is what I'm looking for. I know there was a 3.45 in the 7.5" but I believe it was only offered in the older models that got it's speedometer signal from the cable on the transmission and a specific speedometer cable gear on it's end. I believe mine gets it's signal from the rear end so a 3.45 is probably a "no go" situation.
The questions I have are this......
1) From the reading I see the 3.55 offered in 7.5 open (axle code 85). Does this rear end send the speedometer signal or is it like the old ones that don't do that? If it does send the signal, this is what I am going to look for. Seems like the easiest to swap in. (Same question for the 3.45 open 7.5" but I'm pretty sure it doesn't.)
2) If the answer above is NO then my next option is a 3.55 in an 8.8" rear (axle code 95). This one I'm pretty sure uses the rear end to signal the speedometer and from what I can see should bolt right in. I keep seeing conflicting information on the flange being compatible. Can anyone confirm or deny this?
3) I see a limited slip 3.55 option available in both 7.5" and 8.8" (axle codes F5 and R5 respectively) and a 3.45 limited slip option (axle code F4) in the 7.5". Would these be basically "plug and play" or are there lots of modifications that need to be made? Would they work at all? Are they rare and hard to find?
4) It would be a bonus if any of these options came with disc brakes but if not, I'm not all that worried about it. Any insight on this?
I want this to be as simple as possible without tons of mods and cutting and welding, so the Explorer swap is probably out. Not that I can't do it, I just don't have the time. I work 58 hours a week over 6 days. Down time is at a premium. I would prefer the 3.55 to the 3.45 but would be willing to go with the taller option of it's all I can find. The 3.45 is about 50 rpm lower so I guess I could go just shy of 60 on the blacktops to get back into that 1800 rpm range. Maybe not all that bad an option? 3rd gear in town might be a bit low on the rpms. I don't want to lug the engine.
Any information you all have on this would be greatly appreciated.
Thank you
Thank you
