8cylRWD
- Dec 4, 2009
- Automatic
My 94 ranger with 4.0/automatic has 'automatic hubs'. I have thoroughly cleaned them when I repacked the wheel bearings last winter, and they actually worke for the first time in the four years I've had the truck. Didn't see anything that looked damaged or worn. I cleaned then and lightly lubed them with ATF before reassembly. However today I went to use the truck to pull out some sizeable shrubbery and they would not stay engaged, When I gassed on it the rear wheels would just start to spin and the front hub made a ratcheting noise. The owners manual says no snowplow use for this vehicle, and I've been told by told local guys that these truck are only made to use 4wd in the snow or loose dirt or mud, but not for work purposes.
What's the story? Should I spend the $$ and put manual hubs on it, but is it strong enough to stand up the the input torque? Thanks
