sgtsandman
Automotive Technician
TRS 25th Anniversary
Ham Radio Operator
- Mar 11, 2017
- Aliquippa
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 2.3L EcoBoost
- Automatic
- Tire Size
- 265/70R17
- My credo
- Anything that can go wrong, will go wrong. Plan for it as best you can.
@Rick W
The FE was Fords big engine back in the 50s and 60s prior to the development of the 385 series (IE: 460 big block). Came in displacements of 331 to 428 ci in factory form, with 352, 360, and 390 being the most common. One of the baddest Ford engines of the 60s and 70s was based on it. The legendary 427 SOHC. Stock FEs were heavy at about 650 lbs in stock form, you could drop almost 80 just swapping to an aluminum intake. Last used in the mod 70s. Aftermarket had mostly died out in the 80s but is making a comeback due to dedicated enthusiasts.
7.3 Godzilla is Fords new big pushrod engine that they introduced a few years ago, 2021 IIRC. Small and lighter with as much power as an equivalent displacement FE, plus much better efficiency. Current production, current parts availability and aftermarket support. Where the FE is nearly tapped out (without going wild) at these power levels, the 7.3 is stock and just getting started. Basically it is the modern successor to the FE and 385 series engines.
Every bit of this is about doing what I want. Rebuilding the truck and making it mine. The problem is I don't know which I want on the engine. They are the only two options that hold any interest for me and they both have their good and bad points. I don't have kids or a wife and mom isn't getting any input aside from the shop and financial aspect. Financially it's only if she will let me borrow from the benefits we're getting from dad's retirement and life insurance. Note I said borrow, basically a self financed loan what ever I use gets paid back. Even if I did have a wife and kids they wouldn't get much input in how it gets built, this is for me. I don't too much care about what anyone else thinks, they can rebuild it to suit them or sell it after I'm dead and gone. That is assuming that the thing hasn't rusted to pieces again by then.
I'd about have to be missing an arm or leg to not be able to shift a manual, and if that happens I'll get help to do an auto swap then. My modifications are actually going to make the clutch easier than it is now since I'm converting from mechanical linkage to hydraulic. Truck has power steering and power brakes, those aren't going away, but might improve.
For normal truck duties I'll have a 2021 F-150 and/or a 2000 F-250 Powerstroke, both 4x4. I do want to feel like I can jump in this F-100 and drive to Alaska with no major concerns. I do want to be able to go to Carlisle or Maggie Valley trucks meets with a small camper (3500ish lbs) or a Ranger on a flat bed in tow. None of what I'd pull are outside the norm for a 1/2 ton truck, even a 60 year old one.
Thanks for the words, but I'm really not looking for life advice here, just discussion on the two engine choices.
It sounds like the Godzilla might be the way for you to go then since you don't think the electrical will be a problem, assuming you can find the transmission you want. The rest will just be fabrication to make it fit and mate up with everything else. Working with old engines can be a pain and it seems like you've done your research on getting parts and how easy, or not, they are to get. Room in the engine bay shouldn't be a problem either, unlike more modern trucks.
Don't mind Rick, he means well and he is really just trying to be helpful in his own way.
