funkingonutz
- Sep 1, 2007
- Age
- 36
alright i just got a FREE old school go kart from a friend and its not running right. When he gave it to me he said he did "everything" he could to make it run and failed. (all i saw that he could of done was change the spark plug
its a Manco.....something...its one of those old street ones that are like 2inches off the ground.
its got a Tecumseh 4 stroke motor...not sure of the cc's or the hp. but from i saw on google its a 6horse motor. So...i went to turn it over....noticed the pull start rip-cord was GONE!! Fixed that, then went to see if it had spark....OUCH!!! Yup its got spark, checked the compression, GREAT...pulled of the carb took that apart and cleaned the jet,bowl,inlet. and the exterior with carb cleaner. Then i went and got a fuel filter and new fuel hose. Then i filled the crankcase wit oil...Went to turn her over and she fired right up first pull
BUT.....the rpm's got real high and then it cut out
pulled it over again and the same thing happened.
It seems to run LONGER when the choke is ON and as soon as i take the choke off it dies instantly. Now i used to own an old school honda moped and i knew that carb inside and out but im not used to this one yet...there are two adjustment screws that i dont know does what. Theres one at the bottom of the bowl sticking directly down and one on the side of the carb body...wich one does what???
O and what is causing it not to run?? i forget but i used to know what it ment when it only ran in choke
