Theunknownstep123
I have a 99 2.5 manual 2wd. I’ve checked timing, have spark, replace cam and crank sensors, fuel pump and confirmed I have good rail pressure. Can still not keep the truck running, if I spray it with starting fluid it’ll run for about 3 seconds and run well until it bogs down and dies. Seems like injectors will not fire. Originally though fuel pump was the issue and when I replaced it the truck cranked up and ran for a 10-20 seconds before bogging down and again will now only crank and run on starting fluid. Any next steps would be appreciated!
Fuel injectors are new
Inertia switch is not flipped
Relays have been swapped around and replaced
New computer
Truck has sat for years
New computer
