- Aug 6, 2007
- State - Country
- GA - USA
- Vehicle
- Ford Ranger
- Automatic
- Total Drop
- few inches
- Tire Size
- ~30"
Does enthusiastically running them over count?
Don't get mad me I only did it once and it was my own bicyle. While I did run it over with enthusiasm, it was completely by mistake. I was young. Don't remember age, but less than 10 I'm sure, and my bicycle still had training wheels. I got my first (only) go-kart for either christmas or birthday. Went riding it one time and forgot that I left my bicycle between the house and a tree in the back yard, there wasn't a lot of extra space between the two. Bicycle lost a training wheel, and go-kart went airborne. Go cart landed upside down. It was one of the older ones without a full rollcage, but it did have a "rollbar" that stuck up well higher than my head at that time. Somehow when it landed upside down I was still sitting in the seat holding onto the steering wheel. There was no seat belt, so I can only assume that was probably one of my first experiences with the pucker factor, though it was many (many) years later before I first heard that term.
As for bicycles. I'm a Walmart bike conneseur. Every 5-10 years I'll get the idea that I want to ride. I buy a new Walmart bike, use it a few times, then leave it out to rust up. Never fails.
The most I've ever stuck to riding one was getting around the flight line at work. Long commute from parking lot to assigned work area, and keeping a bike on the flightline made the commute easier. Then it started disappearing for days at a time. Final straw there was when I got to work one day and the wheel was literally folded into an L shape sitting in the bike rack.
Bought another walmart bike to use away from work and it was right backto the usual use it a few times then let the weather get it. No point spending a bunch of money on a bike that is going to get ruined.
Last purchase was the Mongoose Stat 29er from Walmart. Usual story with it. I did keep it stored inside for a long while when I wasn't using it. Eventually it got in the way and went outside. I'm actually thinking about rebuilding that one into an e-bike to take on camping trips and using around the park. Frame is still fine, just need the chain and cables lubed replaced and probably new tires & tubes. Even when it was new I wanted to upgrade the shifters and derailleurs, so that'll probably be done with budget used upgrades if the conversion ever happens.
Sorry, none of that helps with your tube popping issue.
I do support the conversion from Presta to Schrader. Never owned a bike with Presta, but learned about them in tech school. Was never impressed. The typical schrader is simpler, better supported, and more than strong enough for any pressures that a bicycle tire is going to see. Maybe there is some plus to Presta in MTB due to less exposed rubber on the valve stem? I don't ride in those conditions, don't personally see it. There are a whole lot of schraders with an exposed rubber stem in rough use betweeen the offroad automotive crowds and the dirtbiking community, and never heard it is being an overly commonly issue there either.
