shr3dd3r 09
- Feb 24, 2011
- Huntsville, AL
- Total Lift
- 3 Inches
- Tire Size
- 33X11.5X16 (285/75R16)
I tinkered for about an hour between jobs today and I also made a block off plate at work during lunch. It is for the giant hole I cut in the floor for my shifter.
Then I installed it
I took a few pictures but didn't have much time and it started raining again.
Here is the F550 master cylinder, it looks very similar to the ranger version except it has a larger bore and therefore needs the hole it sits in enlarged.
Did that center console assembly come from an explorer with a manual transmission? The reason I ask is because the front panel in the console where your shifter comes through is completely open and doesn't appear to have been cut.
On most Explorers/Mountaineers with the V8 there are either two storage trays or a message center in the front panel (it's not a completely open space). I'll be using a ZF in my '00 Ranger behind my 5.0, so I'm going to attempt to use a similar center console setup so the metal plate covering the cut in the floor is hidden and I can still have cup holders
