ddbc
- Feb 23, 2008
ok i just did a auto to manual trans swap on my 91 explorer I changed the ecm, trans wiring harnes, pedals hooked up the clutch multi switch but havent changed the column yet (I just pulled the pin on the shifter & put the covers from the manual column on it) I have the manual column but I have to drill out the key switch so I was going to wait to install it ok now back to my question I am having a 4 lo problem what it does is it goes into 4hi but when i try to put it in 4lo the light just flashes constantly just like it did with the auto when id forget to put it in neutral Ive checked the nss and even bypassed it so is it possible there is a posision sensor on the column that tells when its in neutral or is the one in the trans the only one ive done everything i can think of except the actual column im at a loss.
