TheBobmanNH
Well you can check the blocked exhaust by disconnecting the pipe from the cat, or the manifolds from the exhaust pipe.
Indeed. I doubt this will be easy with 20 years of rust on there, so I just awnted opinions on whether it was a reasonable guess before I busted out the torch.
My 93 with 3.0 v6 actually has a distributor cap and a rotor underneath it so I'm guessing your 4.0 does, too, but not sure. If it does, see if you can find the firing order for that 4.0, then pull the spark plug on the No. 1 cylinder and turn the motor over by hand (socket on crank pulley nut) until the No. 1 piston is at top dead center (at top of its stroke). Then pull the distributor cap off and see if the rotor is pointing to the No. 1 plug tower/wire on the dist. cap. It should be with No. 1 cylinder at top dead center. If not, your timing is off...maybe your future bro-in-law played with it...or maybe the timing chain/belt has jumped and is off...don't know which one (chain/belt) your truck has. If the timing is off, it can have fuel, air, fire, compression and not start...just backfire as you mentioned.
It's coil-driven ignition (not a distributor), though the timing thing has certainly been on my mind. I just can't reconcile this latest experiment with a broken timing belt / chain.
Sometimes us old farts forget that you younger guys have never dealt with adjustable timing, carbs, and other assorted dinosaur-era features.
Hahaha, while definitely true I'm only in my 30's, my first car was a '79 AMC with a straight 6, distributor, carbeurator, even a manual choke override. And later on I had a '75 Grand Prix. I may not be an old fogie quite yet, but I've definitely encountered a few of the dinosaur features
