- Dec 8, 2009
- Evansville , IN.
- Automatic
Ahh, prefab brackets. Too easy. haha
The brackets come with the dom and ends. I guess I have to use them.
Welcome Visitor! Please take a few seconds and Register
for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
Crunching the numbers, it appears they are going to be way too soft. What did they come off of?
I just did a calc for the effective spring rate of springs in series. So if the coilover was mounted perpendicular to the RA in the vertical plane, under full axle compresison, it would have a PPI of less than 100. That's soft.
Setting that stopper is kind of tricky. Probably take several tries to get it right.If I could've used prefab brackets, I would've. Much easier.
Ahem.
225 over 300 will still be soft, but may work. My springs are 375 over 204, but they don't have a stopper (and the coils never bind) so they act like a linear spring with a rate of 132ppi.
225 over 300 gives you a 128.6ppi until you hit the stopper, then it'll jump up to 300.
With your 20* angle, take those figures times cos(20*) and that'll be your effective rate at ride height (the angle will change throughout the suspension travel, obviously). So you'll be sitting at 120.8ppi until you hit the stopper, then you'll be at 281.9ppi.
Depending how you want the suspension to act, and the style of bumpstops you have, you may be better off with the 225 lower spring. That'd have a 211.4ppi after you hit the stopper.
With a stiffer bumpstop, you may be better with the stiffer lower to take some of the hit before you crash into your bumpstops. Just set the stopper like 1" before you hit the bumpstops.
I need 12" 2.5" but thanks. Plus I ordered them already.^Tooold you.....
Just kiddin. I have a set of 12" 3" 300 springs. They're yours if you want them
You sure your not still runnin TTB? Lmao.... that first pic looks like alot of pos. camber?
