alwaysFlOoReD
⭐Supporting Member
- Apr 13, 2009
- '06, '11
- 3.0L
- Automatic
No vids yet. I took it out for a quick run and it bottomed out quite easily. So I jacked up the frame till the tires were just about off the ground and then loosened, then retightened the three bolts [per side] holding the spring and shackle to the frame. Took it out again and it seemed much better. Blew the rad hose within the first two minutes of hard running
.I had just finished pouring in some Waterwetter too
. Replaced both upper and lower rad hoses and another bottle of Waterwetter, C$65.00. I still have a problem with temperature after ten minutes of hard running. I'll try sloue's suggestion of running about 20' of heater hose to the back of the truck and back, I'll hook up a heater rad too. If that doesn't work then I'll have to put the stock fan back on until I can find a bigger/thicker rad.
Richard
Richard
], some week nights.
