- Jun 1, 2001
- Age
- 63
- 1987... sorta
I recently swapped a later (1993-up) style alternator onto a Bronco2 2.9.
I found that some 1993-ish F150 4.9's use the same
"Pivot bolt at 6 O'clock and adjustment bolt at 2 O'clock" mounting as the old style alternator fitted to ALL 2.9 engines.
After determining that it WOULD physically mount I had to shave ~1/8" off
the integral spacer sleeve on the front side of the V-belt pulley from the old alternator so there were enough threads for the pully nut to hold.
As for "wiring" 1989-92 Ranger have a little short "alternator harness" that
makes the alternator essentially "plug and play"
Though on some vehicles I've needed to splice on a new field connection connector because of a connector gender issue.
Frankly there is no real "need" for a 130amp alternator on a typical 2.9 Ranger.
Though I will admit that I run a 130amp alternator on my 4.0... I also have to say I put that alternator on there because of the same reason a dog licks his balls.... Because he CAN.
AD
AD
