Aftermarket Cold Air Intakes?
DankTank
Oklahoma
If it ain't broke, fix it 'til it is...
A while ago, my stock air box fell apart on me, and I've been using that K&N filter that fits right on to the throttle body as a temp until I can find a better solution. Unfortunately, any stock units are either smashed to pieces, or just plain missing on the trucks at my local junkyard. And I just can't find an aftermarket solution that would be at least as good as the stock setup. I'm also not a fan of having the filter literally sitting on top of the warm radiator, so I'd rather not keep the setup I have now...
If anyone knows a good aftermarket setup, or is willing to sell me a nice stock box in the OKC metro area, any help would be greatly appreciated!
You didnt mention which engine you have but anyway, a couple minutes on ebay and I found several used oem units for sale. Just type in ford ranger air filter box.
If you can't find a "Ranger" air box look at other cars/trucks at wrecking yards, if it was Fuel Injected it has an air box so pretty much every car and truck made after 1985, and you use that models air filter in it, so write it down on the outside of the box
