ABS signal under hood
drewski
SD
On my 2002 Ranger I installed a distance meter that tied into the VSS signal at the cruise control module. The ranger doesn't send out a signal until its going around 6 mph. I need a signal that will produce at slower speeds. I am thinking about trying to use the signal from the ABS in the rear axle. Is there somewhere under the hood I can tap into a wire to get a signal from the rear abs? Thank you
