a4ld squeaking noise?
DOZER
mother lode
my 92' a4ld started making this very annoying squealing sound during a hard wheelin trip. I know for a fact that i over heated it, as it was puking scalding hot fluid from the bellhousing area, but after i let it cool down i topped off the fluid and all was well, no slipping, or chattering it functions perfectly, except it makes this damn squealing noise after it warms up to op. temp. it also seems to come and go wether im in drive or neutral (worse in drive). just wondering if anyone has ran into this before, oh and it kinda sounds like a belt squeal only it does it w/ the belt off, any help/ suggestions would be appriciated:icon_confused:
How much fluid did it puke out? Did you run it long afterwards? Did you get into some deep mud and possibly fill up the bellhousing?
Overheated A4LD is usually a bad thing.
Sorry, but the math is against you because...
A4LD+funny noise = (usually)rebuild A4LD soon. At least that was always my experience to the tune of $$$.
Especially if you are running a 4.0, now's the time to start maybe looking into an M5OD swap.
Good Luck!
