A4LD Shifts late when Cold
Brewman1
I have a 94 4X4.What is the correct shift point (RPM or MPH) from 1st. to 2nd. gear when cold ? Mine consistently sfifts around 3000 RPM and once warm around 2200 RPM. Is this correct or if not points on repair would be appreciated.
Thanks,
Brewman :beer:
That doesn't sound too bad to me. They will shift a bit later cold.
Just check the fluid level, at temp, running, in Park, on a level surface. Make sure it isn't low.
