A4LD shifts hard
Dmil87
I have an 87 XLT with a 2.3L with 110000 miles on it... it shifts hard in all gears, and i was wondering why..... I was also wondering if shifting it from 1 to 2 to D then OD can hurt the transmission (basically shifting manually) I've changed the fluid and filter recently... 2 months ago... please help
Have you checked the vacuum line to the vacuum modulator? Also pay special attention to the fluid level. You might also check the kickdown or detent cable making sure it isnt stuck. Manually shifting the trans shouldnt hurt it as long as you watch your rpm,s and dont over rev it between shifts. Watch your temp gauge and dont get it too hot. Hope this helps. HOSS
