99 wheel bearing change clip question
coyote4x4
Hi All,
Shes up on the jackstands, I'm changing the front wheel bearings. From the info I seen on the forums there is a orange plastic clip that has to be replaced.....not reused, and its only available from the dealer? The clip I took out with the pin pliers was white with a metal lock spring in the front on it (on the hub side if the clip. Can someone help me with this??
Thanks Ron
